Stuck on Boot Logo? A Step-by-Step Recovery Guide
  • Crucial: You must download the correct firmware for your specific head unit model. If you're unsure, contact the manufacturer's support before proceeding.
    Preparation is Key: You will need a computer, a USB drive (or SD card), and a small pin or paperclip.
    Step-by-Step Recovery Instructions:
    1.Please unplug all the wires and then reconnect the head unit.
    2.Please download the update.zip via your computer/laptop.
    3.Please make sure to format the USB drive(FAT32 Format)/SD card before copying the update file to it.
    4.Please ONLY put update.zip file in the root directory of the USB drive/SD card, and then insert the USB drive into the USB cable.
    5.Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select Wipe data/factory reset.
    6.After then, insert the USB drive to the USB cable and re-enter the recovery mode > click "Apply update from SD card or USB" > click "from USB storage" > System update.
    *Last but not the least, please wipe all the datas before proceeding the update.
  • So frustrated I cannot get this to work. Is their anyone at a store or distributor that can assist.
  • @Tim Kubistek
    Dear customer,
    Thank you for contacting Dasaita.
    Here are the trouble shootings:
    1.Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
    NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
    2.Please remove all the wiring and then reconnect the unit.
  • Is there anyone that can help me?  I paid a lot of money for this and absolutely nothing works. No music no CarPlay just a continuous loop of loading and failing.
  • @Tim Kubistek
    Have you tried the trouble shootings?
    May we have your order details so we could check the warranty and the current version for your head unit ?
    Thank you!
