Initally the GPS was ok...not great but ok. it would take about 15 mins to get a stable lock on a few satelites (at least 1-2 green & a few yellow under the GPS monitor)
however after the latest update, I never get any green connections & lucky if I get 1 yellow, mostly they stay gray
I am in the usa, it shows 11, but never connects. The GPS reciever sits right on my dash up against the glass so should be able to get a great signal
I have tried the other GPS settings via the car > factory settings & despite trying all 3 options, I get the same results
@Support Dasaita anything?
@Injineer
System Firmware-G13-20260409:
https://www.dropbox.com/scl/fi/h1e688co7vr53z30rtdlk/update.zip?rlkey=loanzw1z5hay4q0erpzj05qte&st=lp62ulvd&dl=0
MCU-4.17f:
https://www.dropbox.com/scl/fi/9t1gp2mkk3ertqyybpf5j/hmcu.img?rlkey=rs1abdmvfbk53331a024bps8j&st=dzwvztlg&dl=0
If you need further help, please simply contact our team via email.
📩Email: team@dasaita.com
i applied this , & I get 1-3 extra sats connecting , but still piss poor connection / GPS drops out
I even downloaded my area locally w/ google maps but it is still terrible. I have to resort to using my cell....kinda eliminates a key reason I purchased the unit
@Injineer
To better assist you, please record a short video showing the issue and send it to our email address.
Kindly include your Order Number in the email subject.
Email: support@dasaita.com
Not sure what a video will show but here's another screenshot
I've been driving around for about and hour and still no sat locks
My gps sensor is right on my dash also
@Injineer
Thanks for your message.
Please check the GPS antenna port.
Make sure the antenna is properly plugged in and there is no poor contact.
Also, please mount the GPS receiver on the A-pillar, instead of placing it directly on the dash against the glass.
