Toyota Sequoia 2008-2018
I am having an issue with the backup camera not coming on at all when I go into reverse. Nothing happens. I had a dasaita max10 in a 2008 Toyota sequoia platinum and other than the car settings not working, it worked great. I recently switched to a 2012 sequoia platinum and while installing it i noticed that two plugs that came out of the canbus i was using (simple soft ty-ss-01) was not connected to a reverse signal from the Toyota harness. I looked and looked but could not get any leftover plugs on the Toyota side to plug in to the canbus. Did the harness change between years or something? Could someone tell me which Toyota harness if would have the reverse wire in it? Thanks!
