@Mark Wesson Glad to hear that the steering control can work now. It may be the canbus is not stable at that time.
Programmed my steering wheels and then they worked great. Then I didn't update and they did not work anymore. Toyota tundra 2010
Thanks for the help in advance @Support Dasaita
@Ahren Swett Please kindly let us know your order number so that we can locate your order detail and provide more appropriate instruction. Please let us know how long does the issue that you mentioned above happened.
Regarding to SWC, we would like to tell you that if your head unit is with a canbus box, you can just go to the Factory settings > enter "126" > Canbus and choose the canbus option "8".
If your head unit is without a canbus box, you can study under the following instruction.
1) Please go to: Settings > Car > Factory settings (password:126) > Others > SWC KEY assign > Can Key > Apply > Exit (Restart).
2) Please go to: Settings > Car > Steering Wheel Keys > start to program OR just open the App "Wheelkey Study" to program.
If still no luck, please let us know if your UI is MAX or Vivid, we will send you suitable firmware to update.
@Support Dasaita Dasaita 10.2 Car Stereo for Toyota Tundra 2008 2009 2010 2011 2012 2013 Sequoia Carplay Android Auto Radio GPS Bluetooth Navigation Touch Screen DSP 4G RAM 64G ROM
Ordered on Amazon my order # was 112-0228878-0490606
@Ahren Swett In this case, we suggest you could update the firmware to exculde the firmware related issue. Please kindly provide the following information.
@Support Dasaita here is the info as i provideds in a previous post
@Ahren Swett We have replied you in the inbox, please kindly check with it.
@Mark Wesson Out of frustration, I unplugged then plugged the canbus back in. The steerting wheel controls are now functional.
@Mark Wesson It is possible that vibrations caused the connection between the head unit and the canbus to loosen, thereby causing an intermittent connection.
@PAUL JONES It might be one factor, we hope this could help resolve other customer's frustration.
@Support Dasaita how do we know or where can we find the info for our specific Canbus? I just installed unit and can't get the keys to work. 2016 toyota tundra non JBL.
@Adam White
Based on your car information, we initially judge the CanBus model is "CB004".
And please set up the CanBus option is "NO.8":
Settings > Car > Factory settings (password :126) > CanBus > Canbus(inverted triangle) > 8 > Apply > Exit > Reboot.
Hi, recently purchased a head unit for my 10th gen civic off of facebook marketplace. After plugging everything in and double checking, my steering wheel buttons are not working at all. I've tried resetting things and using the factory settings but still no luck. My guess is that the system needs to be updated as I don't believe it has ever had a firmware update but then again I have no clue. Thanks
@Jake Bruner
Hi Jabke,
If you car years is 2016?Could you please provide your order details which is included the order ID & unit model,so that we could better confirm the specific model you're having.
I’m experiencing an issue with my car stereo. The steering wheel controls, including the volume up/down and skip buttons, have stopped working. Additionally, the five buttons on the left side of the radio screen are no longer functioning.
I purchased the unit on Amazon on May 28, 2021 (Order #111-9912705-7313038). Could you assist me with resolving this issue?
Hi, my name is Aramis. I purchased a Max 10 PX6 and my Zlink was not working; it kept saying "not activated." I updated the firmware to Vivid 10, and Apple CarPlay is now working. However, my steering wheel controls for skipping songs (left and right) are not working. Please let me know if you can help me. I have a 2017 Nissan Rogue SL with a 360 camera.
Thank you in advance.
@Aramis Gonzalez We are wondering if you could go to Settings > Car > Factory Settings(126) > Canbus > Choose Option No.10. Meanwhile, you could also check if other steering control buttons could work or not.
Thank you. After figuring out the right wheel control setting to skip the song track. it working pefect thank you. Below is the setting I have for my Nissan Rogue
@Aramis Gonzalez
It is our pleasure here.
For any other helps,please get in touch
Recently installed G13 in 2007 Tundra Limited (JBL, no OEM Nav). Programmed SWC, which seems to work fine in radio app. But when I change to Amazon music via Android Auto, SWC works sometimes and sometimes does not respond at all.
Update: experienced same behavior with radio also. Is there a solution to try? I've tried reprogramming SWC buttons again. Now just switched back to CAN 8 setting, we'll see if corrects.
