How to wire backup camera
  • Backup camera wiring tips
    1. Make sure the RCA video cable has been connected to interface 11 correctly.
    2. Connect the rear camera connector with the yellow plug labeled "CAM VIN".
      Note: If the screen displays a yellow exclamation mark when you're reversing the car, there must be a wrong wiring issue. You should refer the above wiring tips to check or you can check the wiring tips on our listing description.
      Here is wiring instruction of the after-market camera.
      Note: If the head unit’s without a CANBUS, it should have to connect the reverse cable as you shown on the picture below.
