Is there a way to set the region other than China resulting in correct time zone and time and date from GPS?
Another question! Can I change the rear camera settings? With the original system the vision has much improved
@Celestino Siddi
Please try to do as follows:
Settings > System > Date&time > Time zone.
@Celestino Siddi
For further confirmation, pleaes tell us what settings you wanna change,
and whether your current rear camera is the original one.
@Support Dasaita already tried it can't be changed
@Support Dasaita The camera is the standard one, I would like to try to modify the sharpness, contrast, etc., etc.
@Celestino Siddi
Regret to tell you about it doesn't support to change the related settings.
@Celestino Siddi
Please go Settings > About Machine > Model; Android Version; Build Number; MCU version,
then send its photo(see pic) to us.
@Celestino Siddi
Please try to update the firmware to see how it goes.
Step1.
Step2.
Step3.
Step4.
Step5.
Before updating the system to try to solve the bug of the non-editable region, I would like to know if I will then have to configure the entire car tablet with my settings because if I have to redo all this, I prefer to leave it like this
what would be ALL the Canbus settings for Tundra 2020(no jbl system), factory amp under passenger's seat. It seems is #8 but there are more options (PRADO, etc). ty :)
@Support Dasaita I have a Nissan Quashqai J11 MY2019. My dasaita is G12 firmware is QCM6125_20240812. From last two firmware update CAM button dosn't work. I tried cunbus 10, Left rudder, 1 Type HI, AVM 1 and cunbus 37 ...don't works! any solution? Another problem before update is the car clock in 12:00.
@ALESSIO FRATTARUOLO Hi ALESSIO,
Please keep the settings same as before the camera can work properly.
And then please take a video of showing what's display on the screen when shift into reverse,so that we could better confirm.
Thank you for your time in this matter!
@ALESSIO FRATTARUOLO Do you mentioned that the time of the unit and the car clock are not synchronized?
@Support Dasaita Correct, car clock remain fixed at 12:00. Sometimes set the hour when I start the car but stay fixed.
Hi Alessio,
Is the issue of the 360 camera getting resolved?Was the firmware is QCM6125_20240812 now?
Regarding the issue of the clock display,please go :
Settings > car > factory setting (Password: 126) > CANBUS > choose the CANBUS option is 0 > restart > apply > exit. After rebooting the unit,please go back to the canbus setting to choose option 10,then apply and exit.
If you try but no luck,please kindly get back to us,thank you.
@Support Dasaita doesn't work. When I start the car the clock was correct and the 360 cam button working but just for 5/6 minutes. After these minutes the clock stay fixed and 360 cam button stop to work.
