Dear Dasaita team,
I'm going to install an aftermarket front camera to my Honda CR-V 2011 with Dasaita PX6 Android 9 RK3399 head unit. I have a good wiring diagram for rearview camera in the manual, but there is no data for the front camera.
On the wiring scheme it has F CAM IN input jack + F CAM + wire.
Thanks in advance for your support!
Alex.
@Alexander Potayenko
Hi Alexander,
Here is the details for your reference:
Thanks a lot, guys. I'm really happy that I've bought Dasaita head unit and have high quality product, aftersales support, updates, etc. Thanks for your customer care!
Hi Alexander,
We'd be appreciated that if you could let us know how you like our customer service.Your comment really matters and helps to keep us motivated.
@Douglas Patino
For further confirmation, please tell us if you want to purchase "RCA cable" and "AUX In & Cam In cable"?
Hi. No, thanks I have them.
Hi. There is a mistake in the rear camera connection scheme you provided. Camera power onnection should be done not to "Reverse" wire but to "Back" wire.
There is also a problem with the front camera connection. When connected as shown, the picture is dark-grey, almost not visible. Camera side power + is connected to the wire which comes from "Front Cam power" wire. Can it be low power issue? Is it ok if I connect the camera power to some ACC 12v + and Ground? And should I leave Front Cam power wire connected in this case?
Yes,the ACC also with 12v to power the camera@Alexander Potayenko
Hi guys.
I have a problem with the front camera input. Please see the screen photos when I plug the camera into F Cam In. The picture is dark and almost not visible. When I plug it into Cam In it shows perfect clear picture through the AVIN.
Can I fix it in some way or it's impossible?
Front camera power is connected to 12v now, not to F Cam Power wire. With F Cam Power the picture was the same.
The same - i mean it also was dark.
@Alexander Potayenko Hi Alexander,
Do you mean when connect the F-Cam canbel the image can be display,but just the picture is dark and almost not visible?
Yes, exactly. And when the same camera is connected to AVIN the picture is super good.
Any ideas, guys? Maybe sometimes you already meet something like this.
If AVIN cable is work,you may connect it to AVIN too.There may be a problem with the front channel image signal processing or RCA.
MCU version MTCE_HA_V3.37_1
Serial number D689902C2299D00E
Can't upload photo, don't understand why
