Is it possible to adjust the trajectory lines of reverse camera? Currently those are fixed and I can not adjust those. I also have OTTOCAST screen and reverse lines can be adjusted there right on the screen.
@Roman Khmil
Hi Roman,do you mean to adjust the trajectory lines of factory reverse camera?Is it inaccurate?
Yes, exactly. The lines which Dasaita unit provides are fixed and I can not adjust those to match the parking spot better. Other units allow to adjust lines with finger by dragging those. And I wonder if this is a unit which should allow to do that or camera itself?
@Roman Khmil
Hello ,
The unit doesn't allow to adjust lines with finger by dragging
You could go Settings> Car >Extra Settings> Reversing Trajectory Display>OFF .
