Toyata Tundra 2018, non-JBL,poor audio
  • I purchased an Android G13 and installed it in my 2018 Tundra, non-JBL truck.  It's a definate upgrade as regards capabilities.  The sound quality is lacking, however.  It seems to rely heavily on the smaller front speakers making the sound 'Tinny.'  I have adjusted the Amplifier/Equalizer in numerous configurations.  I am able to get a little more volume from the rear speakers, but the sound from them is muffled and 'Muddy.'  The sound quality is markedly inferior to that produced by the original Toyota Head-Unit.
    I purchased, configured and installed an Amp Bypass Harness with no improvement to sound quality.
    I am using the stock Toyota speakers.
    I verified the Model number is QCM6125.
    Android version is 13.  Kernal 4.13.190.  Build number:  QCM6125 13 S10A_123 eng.hct20241022.090634 NA
    MCU version is: MTCHS_HA4Z_V4.15a_1   Nov 14 2024 15:38:58
    CANBUS is set to "08 TOYOTA_CAMRY&RAV4(Simple)"
  • @Kenneth Ward
    Thanks for your message.
    We just released a new firmware.
    Could you please try to do the update to see how it goes?
    System Firmware-G13-20250212:
    https://www.dropbox.com/scl/fi/vlisvslcxnjaorf4bovg2/update.zip?rlkey=x0l7zfeg7rcf3lgey563d481m&e=1&dl=0
  • @Support Dasaita   Per your instructions, I downloaded and installed the G13 20250212 Firmware Update.  I made a difference.  The sound quality seems a good bit better.  I hesitate to call it excellent, but it is much improved and acceptible.  I Hope to be able to tweak the equilizer setting and make it even better.  Thank you for your quick attention to this issue.
  • @Kenneth Ward
    Glad to hear that it is much improved after the update.
    About the equilizer setting, we will report your idea to our technical department.
    We will inform you if we make further optimizations in the future.
    We value your opinion and strive to offer a high quality service.
    As such, we invite you to share your experience and customer service evaluation via below link if this will not disturb you.
    We genuinely appreciate your attention to this matter.
    https://www.dasaita.com/products/dasaita-qualcomm-10-2-car-stereo-for-toyota-tundra-2012-2022-wireless-carplay-android-auto-car-radio-qualcomm-665-android-13-10-2-qled-screen-wifi-4g-lte-6g-8g-64g-256g-dts-head-unit-optical-output?_pos=2&_sid=cc885feb3&_ss=r#judgeme
  • Help!
    Exact same Timney sound quality issue!
    Additionally, horrible radio reception.  (Set to proper country)QCM6125
    ANDROID 13
    Kernel version
    4.14.190
    #139 Mon Dec 23 18:41:45 CST 2022
    Build number
    zst27 QCM6125 13 S10A_123 eng.hct.20241223. 182400NA
    MCU version MTCHS_HA4Z V4.15a_1 Nov 1420244 15:38:58
    IMEI 865851051664837
    CPU
    Quad-core Cortex-A73 @2.0G Quad-core Cortex-A53 @ 1.8G
    Memory
    7822MB
    Serialnumber CC058B5886A98233
    IP address Unavailable
    Wi-FiMAC
    Device Wi-FiMAC address Unavailable
    Bluetooth address
    dc:0d:30:b5:92:03
    Up time 4:44:49
    Help please??
    @Devin Hamden Please update the Firmware & MCU to the latest version via the link below,here are some tips to help you get it done:
    zst27_sc138_13_(20250311)
    ②4.15f:
    https://www.dropbox.com/scl/fi/zjk57mppsli9nnmc9vubs/hmcu.img?rlkey=buxs8jrlxzn00j4488ze6sc0d&dl=0
  • @Jeffrey Jeffrey
    May we have your order ID ?
    please go to Settings>About machine and provide the following version information:
  • Hello. I am having the same issue with my 2014 Toyota Tundra SR5 crewmax 4X4 non JBL. The sound is loud and clear coming from the dash and center channel speaker, but the door speakers (front and rear) are muffled . I have tried messing with the fade/ EQ but i cannot get them to get any clearer or louder.
  • @Joey Garza We are wondering if you could go to EQ settings to move the sound spot to the center and see if the issue will be fixed or not.
  • It did not fix the issue. The speakers in the front and rear doors have sound, it is just low volume and muffled. The dash speakers are very loud. It is non-JBL but there is a factory amp under the pasenger seat.
  • @Joey Garza In this case, you could kindly update the firmware to the latest version and see if the situation will be improved or not.
    G13(20251031)-V2:
    https://www.dropbox.com/scl/fi/eo78wxbu8oh59jp8dg33u/update.zip?rlkey=lftf2p8qyyrl0act82bxgvpsu&dl=0
    Update tutorial:
  • I have this same issue in my Tacoma. I've updated my headunit to the newest android 13 I've been sent as of 2 days ago. I'm not sure what else do. It seems to be more of a problem with the MCU which I have also updated 2 days ago. I'm not sure if it's because Toyota has the tweeter speakers tied in with the front speakers but the front and rear speakers don't pus hardly any sound compared to the tweeters.
  • @hudsun farnsworth
    Thank you for your contact .
    Does your car have a factory amp?
    If not, please try to reinstall back to your OEM head unit ,then go to the EQ  to Reset settings.
  • @Support Dasaita it does not. Ive messed around with a few canbus settings I was able to get it a little louder but not ideal. I do also have aftermarket door speakers. So I know it's not a speaker issue.
    Could you please let us know what CANBUS settings you have configured?If the vehicle is not equipped with a factory amplifier, you can only adjust the related settings in the Amplifier app > Volume.
    Additionally, you mentioned an MCU update earlier.Please let us know the MCU version before the update and the current MCU version.
    Thank you!
  • So I was having the same issue. Downloaded and installed the update as mentioned in previous posts. It now is just stuck on the android boot screen. Rebooted 3 times on its own, about 15 minutes between the reboots.
    qcm6125
  • @Eric Byers
    Dear customer,
    Thank you for contacting Dasaita.
    Here are the trouble shootings:
    1.Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
    NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
    2.Please remove all the wiring and then reconnect the unit.
