Since this G13 is not certified some apps in the Google Play Store will not install. I already tried the procedure in this video How to Manually Add a Device to Google Play Protect Certification but so far that did not work. Is there any company response on how to do this or why its not certified?
@PAUL WELSHEIMER We have ceased publishing OTA firmware updates because the previous OTA releases led to many customers frequently installing updates that were prone to causing issues. Therefore, we no longer provide OTA firmware updates. If you encounter any problems, you can contact customer service at any time. Our customer service will determine whether a firmware update is necessary and then proceed with the update. Regarding the apps you mentioned cannot be installed, could you please specify which apps? We will confirm with our engineers.
@Support Dasaita The app that I found the not certified error is Scanner Radio by Gordon Edwards. I have contacted the developer (Gordon Edwards) and their reply was:
"The problem may be that the device doesn't pass the Play Store's "Play Protect" certification check, a requirement for the app to be installable.
You can check the device's integrity check status by following these steps:
Launch the "Play Store" app
- Tap on your profile picture icon (displayed in the top-right corner of the screen)
- Select "Settings"
- Select "About"
- See the text that is displayed below "Play Protect certification"
Current Version of installed stereo
Order placed March 6, 2025
Order # 114-4002756-3081014
@PAUL WELSHEIMER Could you please download the app on your phone and then connected to the CarPlay to car radio to see if the Scanner Radio app work on Carplay page?
@Support Dasaita Yes the scanner radio app works fine through car play. And I do understand that I could just use it this way but I do not always want to have my phone be the "internet" for the stereo.
@Support Dasaita I am having additional problems - I tried downloading the Sirius XM app and I signed into it and it quits. This should not be this dificult to get apps to install and/or work
@PAUL WELSHEIMER Do you mean you can't run the Sirius XM app on the unit?
@Support Dasaita that's correct. After downloading it and opening it, it looks like it will launch and then dumps me back out to the screen where the app sits.
@PAUL WELSHEIMER
Thank you for your reply.
Do you download it as local app on unit ?
You could download on your phone and it will work via Carplay
@Support Dasaita I understand all that ... but what's the point of having a well connected stereo that I spend a monthly fee to have a SIM card in it and I cannot use any of the apps that I would want to in the car (without having to do CarPlay). And since the mic sucks for phone calls I might as well use my phone on speaker. Very disappointed in this unit so far
@Support Dasaita are their any plans to allow the Sirius XM app to work again? It was fine in my Max10, Vivid11, and G12. Then after a few months the app would no longer work with the G12. I hate Android Auto and streaming SXM via BT sucks. Please provide better support to your product.
@John Donnelly
For further confirmation, please tell us whether Sirius XM App can work in the first few months.
If YES, please go Settings > About Machine,
The SXM app worked in my G12 for a few months before it stopped and I have the same experience now as the OP indicated, looks like it will load then it dumps.
I provided but it didn't show up. Needs approval I guess?
Android Version 12
Build QCM6125 12 S10A_123 eng.hct.20240713.084755 NA
MCU MTCH_HA4Z_V4.06_1 Sep 11 2023 20:01:17
@John Donnelly
Please try to do the update to see how it goes.
System Firmware-G12-20241126:
https://www.dropbox.com/scl/fi/6dbw1w89lzhx2q1mvm3vz/update.zip?rlkey=4gfbn509llpqhi4w8nyqxm6h2&dl=0
MCU-4.12b:
Thank you. Before I try what are your thoughts on my updating to G13?
Hi, I performed the updates and the SXM still does not open...starts to then closes. Does it twice then comes up with an error window that allows you to clear cache and storage. Still doesn't all SXM to open and run. Can't seem to upload video.
@John Donnelly
Please try to delete and reinstall SXM App to see how it goes.
If no luck, please record a video about the issue then send it to our email,
and indicate your Order Number in email subject.
✉️Email: support@dasaita.com
I sent the email. Thank you for your continued support!
@John Donnelly
Thank you.
We will arrange the personnel to follow up.
