The head unit is able to read and play mp3 files on the attached USB drive without issue. The next time the vehicle is used and the head unit turns on, it displays the last song played but can't play it. it just shows the default player trying to play it (spinning circle) I need to remove the USB drive and re-insert it for it to play.
@Johan
@Johan
zst27_sc138_13_(20250311)
②4.15f:
https://www.dropbox.com/scl/fi/zjk57mppsli9nnmc9vubs/hmcu.img?rlkey=buxs8jrlxzn00j4488ze6sc0d&dl=0
That didn't fix it and now my user interface is completely different.
My unit not the G13, it is the Vivid. So I downloaded the correct firmware but issue still happens. Unit does not play music files from usb after restarting. Need to disconnect usb drive and plug back in.
@Johan Hi Johan,
Please proceed the updating of Vivid version,if the USB music still not play in that case,please record a video to us,thank you for your time and patience in this matter.
①Vivid13 Version:Make Sure your unit is QCM6125 Andorid 13
1.Download the documents through the link on your computer/laptop.
2.Format the USB drive(FAT32 Format) before copying the Update.zip file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
@Johan Could you please also check if this setting is enable:
Settings > Car > Extra Settings > Playing Music > On
