Hello @Support Dasaita ,
I noticed there are 2 versions of the new QCM6125 G13 firmware. What is the difference between the two?
Android 13 Update
G13 Version: Ensure your unit is QCM6125 Android 13
Thanks!
J
@J L
For your information, V1 and V2 are mainly used to differentiate the core board versions.
Please go Settings > About Machine,
So that we can learn your version information.
Hi, in this picture, there is no version. Which version do I have to download?
@HL
Based on your picture, it is V1.
Please check the update tutorial below.
System Firmware-G13-20251030:
https://www.dropbox.com/scl/fi/z47cujybwxdgj15bokfbz/update.zip?rlkey=cbh8x18aszp1vj9pso77u154e&dl=0
MCU-4.17a:
Welche Version muss ich laden V1 oder V2?
Aktuelle MCU Datei kann ich auch nicht laden, wäre beschädigt ?
@AO1967
MCU-4.17a:
@Support Dasaita Nochmals vielen Dank hat alles bestens geklappt!.
@AO1967 We are glad to know that your problem has been resolved and hope you could enjoy the radio.
If you have any confuse during the usage, please don't hesitate to contact with us.
From what you state where is v2 update I only see v1 update only.
@Edwin Viruet
Build: zst27_sc138_13_V2(20251031)
@Support Dasaita Thank you for the G13-V2: But how about the MCU ?
Question is there a big difference beween G13-V2: vs G13-V1: main software only not the unit it self?
And can you ruin your G13 if you install the wrong one? Why I ask cant find the info on it!
The zst27_sc138_13_V2 will help with my mic issue or that's a MCU issue.
I also have massive problems with the steering wheel control not working to.
@Edwin Viruet Please Delete!
@Edwin Viruet As to MCU update:
https://www.dasaita.com/community/forum/topic/209455/update-on-mcu-support-downloads
You could let us know if your order number, car year and trim level so that we could better help with the steering wheel control.
Toyota Carolla 2014 , If you email me I can give you my order #
You didn't anserwed my question about :
I will be doing first main build then MCU . I'll let you know if it help?
@Edwin Viruet If you did the update but still no luck, you could send us the issue with order number to 💌support@dasaita.com.
