@Tony Ye Wow, thank you so much! That fixed it! Also, do you know If I need to have a canbus selected in the extra car settings? I have a unit for the 6th gen legacy, but I have no canbus selected, it did not come with the little external canbus box connected to the wiring harness, So it does not display the car door information or a/c or anything like that on the screen. The steering wheel controls are mapped out through the SWC app on the dasaita. It would be nice to have the headlights controlling with the LED lights on the headunit as well. Any help would be much appreciated. Thank you!
Bluetooth is still broken with "HA3_rk3399_11.0_ota(20220705)" and "Auto Sleep" enabled. After turning off the car and turning it back on later, the stereo thinks it is still connected to the phone via bluetooth even though it is not. It does not attempt to actually connect to the phone, the phone does not see a connection attempt, any attempt to initiate a connection from the phone is unsuccessful, and the radio will not allow to disconnect bluetooth and reconnect. The radio must be rebooted each time or bluetooth does not work - hence "Auto Sleep" is STILL broken...
@Tony Ye Yes, that setting is on. But even if I turn that setting off, if I turn the car off and turn it back on some minutes/hours later the radio still thinks Bluetooth is still connected to my phone even though in reality it is not.
What version could I use to upgrade the unit for Android and MCU (I suppose for MCU, I could use : 3.78๏ผhttps://www.dropbox.com/s/3hd3ci3rp07ddnt/dmcu.img?dl=0)?
@Matteo Di Marcantonio Hi, if you are not very familiar with the Android system upgrade process, I would suggest that you stay on 10. If you do want to upgrade it, please refer to the topic "IMAGE Update (Android 10 to Android 11)" under Technical Supports. As you can see, many people suffered pain when doing this. Strongly recommend NOT to do it. It took me several days to get it solved.
@Edoardo Edo Of course, the topic "IMAGE Update (Android 10 to Android 11)" I mentioned was released by Dasaita. But they removed the link of the system OS image file.
