  • Hello px3 7.1.2 firmware link not working. Pls update link.
  • Hi,
    Latest Vivid 11 update is very buggy, lots of restarts, and feels much slower loading apps than the previous update. Also having issues with some GPS apps I did not experienced before.
    MAX11 Version๏ผšMake Sure your unit is PX6 Andorid 11
    HA3_rk3399_11.0_ota(20221122)
  • @Iker Gomez i'm scared...
  • @Quick Yuan  hallo, gibt es für das PX5 ein update oder kann ich downgraden ?
    mit der software HA3_PX5_10.0.ota2820220401 gehen keine googeldienste mehr .
    danke
  • @Rudy Hervas you can...but what for?
  • @John Doe there is an option on the car settings of the unit to adjust the volume level while in reverse . By default is volume.disabled....you can enable and put the same or lower level
  • @Vaycheslav Sindjakov is possible but not recommended....unless you were a experimented in flashing devices.
  • @David Anderson use the closest model from your car brand canbus from the manufacturer "simple"
  • I have tested and confirmed Reverse Volume is now working in the latest VIVID version. Thank you!
    Vivid 11 Version Make Sure your unit is PX6 Android 11
    telenav_vivid_rk3399_11.0_ota(20230107)
    https://www.dropbox.com/s/cbs1abtvzfgch49/telenav_vivid_rk3399_11.0_ota%2820230107%29.zip?dl=0
  • Please bring back the Car LOGOS and get rid of the Dasaita animation.
    With the latest Vivid 11 firmware we lost all car logos intro.
    Even when the "Car Logo" is custom set on System settings via password 126 it does not work on boot.
    Now with the Dasaita animation, the unit takes much longer to boot (this is no good)
    Can you please bring back car logos and have an option to disable Dasaita boot animation?
  • @Zeek World They had to remove the logos for copyright reasons
  • I want to update the Android if available, but I'm not sure of the correct build and link, could you please help?
  • When will there be a new Max 10 update fixing the reverse volume problem? Would I be able to download the latest VIVID 10 update and delete the vivid launcher?
    Android 10 Update
    MAX10 Version๏ผšMake Sure your unit is PX6 Andorid 10
    HA3_rk3399_10.0_ota(20221111)
    https://www.dropbox.com/s/uzigr30m8p4cpaq/HA3_RK3399_10.0%E5%8D%87%E7%BA%A7%E5%8C%85%2820221111%29.rar?dl=0
    Vivid 10 VersionMake Sure your unit is PX6 Andorid 10
    telenav_vivid_rk3399_10.0_ota(20230112)
    https://www.dropbox.com/s/fopysof68tx9b1m/telenav_vivid_rk3399_10.0_ota%2820230112%29.zip?dl=0
  • what about showing a changelog of newest firmwares?
    Please forgive me, but I am a bit confused. I have installed a Dasaita with Scout 13.3 inch Wireless Carplay Double Din Stereo Android 10 Bluetooth Radio Android Auto Head Unit GPS Navigation 1920 X 1080 HD 4GB 64GB PX6
    I had previously installed and the unit is running telenav_scout_rk3399_10.0_ota(20221110).zip. But I do not seem to see a compatible version listed anymore. I tried to install:
    Scout 10 Version : Make Sure your unit is PX6 Andorid 10 Version
    scout OS3.1
    https://scout-ivi.s3.amazonaws.com/v3.1/3.1.5/telenav_s4c_rk3399_10.0_flash(20221219).zip
    But the unit would update when I inserted the image file on a USB into the unit. Please tell me what version is the latest for this unit.
    Thank you!
  • Yeah, for some reason Scout OTA Firmware updates aren't available anymore and now they only have the OS image available. Odd.
    With the removal of the car logos, that's fine. But now with the latest Vivid version, even when setting a custom logo it doesn't work, and only the Dasaita intro animation logo is shown regardless as Zeek World mentioned.
  • @wally nzk
  • @The Elite @Flame Red I think it is a mistake when publishing the OTA on this firmware section. This is the link for the OTA itself:
    https://scout-ivi.s3.amazonaws.com/v3.1/3.1.5/telenav_s4c_rk3399_10.0_ota(20221219).zip
    I personally tested this OTA in my unit successfully.
    Scout sytem, from version 3.0 features live OTA updates.
  • @Zeek World The unit with -the Dasaita animation takes the same time to load the rom.
    remember that there is an option to avoid restarting the unit each time the engine is started. by this option, after the engine is shut down, the unit goes into sleep mode htat only consumes a few miliamps (other accessories of the car consumes much more power than the unit at sleep state) and never you will get without battery , as the unit has a voltage meter that detects when the voltage has been dropped and it shuts off the unit completely.
  • @wally nzk
    I would reommend you the latest VIVID one:
