  • <deleted>
    Is it possible to update my PX6 from Android 10 to Android 13? If so, could you please tell me how?
    I'm having a problem with my iPhone 17 Pro Max and CarPlay keeps cutting out, hence my interest in upgrading it.
    Thank you in advance.
  • Hello.
    For your information, it doesn't support to update the later Android system from Android 10.
    Go Settings > About Machine, then provide the below pictures:
    Model; Android Version; Build Number; MCU version
  • @Support Dasaita@Quick Yuan    Hi...
    I have a g12; I tried updating the G13's MCU and since I no longer had sound, I went back to 4.12b.
    Now I no longer have the external mic set to "other" in the factory settings.
    Pls help me
  • Subject: Assistance with Dasaita Unit Firmware
    Good day, I hope everyone is doing well.
    I recently purchased a 2019 Toyota Highlander equipped with a Dasaita unit. However, the unit has started displaying a black screen intermittently. I have tried restarting the unit and also disconnected the negative battery terminal for a few minutes, but there has been no change. The unit itself seems to work, but the screen does not display properly.
    I was hoping to get some guidance on how to obtain the correct firmware so I can download it, place it on a USB drive, and upload it to the Dasaita unit. To hopefully fix the issue. Any assistance would be greatly appreciated.
    The details of the unit are as follows: AW-22-01-3770. Hopefully, that helps.
    G
  • @Giovanni Carollo I Was actually able to locate a picture had taken of the unit prior to black Radio model
  • @Support Dasaita Will you please provide the MCU for the G13. I just recovered from a boot loop and had to reset all my settings. Seems like a good time to update.
    • Android Version
      • 13
    • Build Number:
      • QCM6125 13 S10A_123 eng.hct.20250311.103730 NA
    • MCU Version:
      • MTCHS_HA4Z_V4.16F_1
      • Jul 30 2025 16:20:57
  • @Giovanni Carollo
  • @ZCline
    System Firmware-G13-20251030:
    https://www.dropbox.com/scl/fi/z47cujybwxdgj15bokfbz/update.zip?rlkey=cbh8x18aszp1vj9pso77u154e&dl=0
    MCU-4.17a:
  • @Pakoner
    For your information, the current software already removed the related setting about microphone.
    Without connecting external microphone, the unit will use internal microphone automatically.
    But if you connected external mic, then the unit will use external mic by default.
    I had set the external microphone by default;
    now, without connecting an external microphone, I have no working microphone.
    I have purchased a used vehicle with this unit installed already. Build /MCU
  • @Pakoner
    To ensure the quality of your calls, we suggest that you install the external microphone as well and locate it to a closer point to the driver as possible.
    The top of the steering column or onto the dash are the recommended positions.
  • @Giovanni Carollo
    Please check the update tutorial then give it a shot.
    System Firmware-MAX11-20230608:
    https://www.dropbox.com/scl/fi/ye2ia7nmb9d7cn7z9n424/update.zip?rlkey=m14rlfbbz5fdig0mpjmn8ycw8&dl=0
    Good day, and thank you very much. I have updated the system firmware as per your advice; however, we are still experiencing the screen going black, which is becoming very frustrating. I have checked all connections, and they appear to be fine. Could you please advise on what else can be done to resolve this issue? Thank you in advance
  • @Giovanni Carollo
    For further confirmation, please go Settings > About Machine, then send your current Build Number photo to us.
    Good day, please see below
  • @Giovanni Carollo
    Upon checking, we notice that your photo still is the previous one.
    Please go Settings > About Machine, then re-send the current Build Number photo to us.
    So that we can confirm further.
