Remote turn on wire?
  • Does the head unit have a remote turn on wire for a amplifier? What color is the wire?
  • I am also interested in knowing this. Please provide picture.
    I am currently using additional hardware for Remote Turn on Because I couldnt figure it out.
  • @Kevin Martinez how did you do it?? I'm thinking of ditching my headunit all together and going with an alpine.
  • @MICHAEL VASQUEZ i double checked my wires located at the back of the headunit, and didn't really still much. I did see a blue and white wire, but it was located in one of the harnesses. It was not labeled amp. Typically in the name brand headunit the blue/white cable in the remote turn on wire. How does your system sound?
  • @Ara Gureghian I had previously used original head unit along with a line out converter for my current amp speaker setup https://catalog.pac-audio.com/catalog/audio-interfacing/aoem-maz2
    When I purchased the Dasaita PX6 MAX10 i couldnt figure out the Wire and ultimately destroyed the old harness, had to buy a new one, and used it in conjunction with this lineout converter JUST for the remote wire.
    Id like to stress that this Line out converter is specific for my car model so it may not be what you need, this is just how i rigged mine because i couldnt figure it out and didnt want to destroy a second harness.
  • On the harness there is a antenna power wire (solid blue) which is with the antenna plug. This sends power to the antenna when the radio is turned on. Take your meter and measure that voltage at this point and you should have 12 vdc which can be used to turn on your amps remote line.
