enlarge rear camera image
  • I installed the latest firmware for the G13, and it subsequently reduced the image of me reversing with the car next to it. You can see it
    . Also, the firmware is this one: G13 Android 13 Qualcomm 6125 20250311 zst27_sc138_13 (
    le lien https://www.dropbox.com/scl/fi/70whgvgq7f6fkkd42ncie/update.zip?rlkey=a036rb694v0nehdqh11omokvw&e=1&dl=0 )
    before this update when I was reversing I had a great view of the reverse gear.
    thanks for the help in advance.
    I will so happy.
  • Hi ,
    Do you prefer the full screen of the rear view?
    There are many customer reflected that the full screen of the rear view will stretched the image,because the screen is bigger than the factory radio,so the image will a little bit stretched,so we upgrade it,so that it will closer to the original car's rear view picture.
  • @Support Dasaita perhaps is better to have an option to select it.
    In fact that view of the car on the left when you have no reverse sensors is useless.
  • Hi all,
    As Twin Gomez said, can we have the option to enable it or not? Or an option where we can set the default camera to zoom in without the car next to it.
  • @Iker Gomez @Mohammadou Mahdyou L Cissé Thank you for your suggestion,we will reflect it to the engineer to look into this and will get back to you guys soon.
  • @Support Dasaita Yes I have this little car and I don't like it. How can I remove it and go back to the regular full screen of the reverse camera
  • @Kenneth Williams
    For your information, the current version doesn't to display the full screen of the reverse camera.
    Our technician is optimizing software to add full screen option.
    We will inform you further once it is available.
    Thanks for your patience in advance.
  • @Mohammadou Mahdyou L Cissé
    Glad to tell you we just released a new firmware to add full screen display option for backup camera.
    After the update, please put in reverse gear and tap the upper left corner option to switch full screen display.
    System Firmware-G13-202504523:
    https://www.dropbox.com/scl/fi/a5h978wsreg9uuipf6bw1/update.zip?rlkey=p77ztea3f3gdhu24t0845i2mq&e=1&dl=0
  • @Kenneth Williams
    Hello again.
    We'd like to know if your Dasaita headunit is G13.
    For further confirmation, please go Settings > About Machine,
