2017 backup camera isn’t working
  • I made sure all the connections are good. Everything is correct. Especially for the backup camera but nothing is working. I connected my old head unit and that back up camera works.
    i need help. Is it the wires that came with the new head unit?
  • @Leonardo Vega
    Check if the Reverse Camera is Enabled on Factory Settings:
     Settings - Vehicle - Factory Settings (pass:126) - Others
    you will find a setting for the Reverse Camera there.
    If, efter enabling it, it still does not work, try the following:
    Backup camera is controlled by the CanBus box. Check if your Canbus box is properly configured to your Car Brand/Model and Manufacturer of the CanBus Box.
     Settings - Vehicle - Factory Settings (pass:126) - canBus
  • @Leonardo Vega
    Please  notice to connect the yellow cam vin of audio output & cam vin cable and connect the CANBUS .
    If it is still not luck,please the below information:
    1.Order ID
    2. A picture of your OEM unit.
    3.Some pictures for your connection.
    Thank you for your time and cooperation
