Toyota RAV4 2019 gen 5 Front and reverse camera not working
  • Hi evereryone,
    After switching off the power I removed the original radio next, I carefully connected the Dasaita Android13 Car Stereo. Everything seems to work, except the cameras; when parking both the rearview and frontview camera's don't show any image. I get a black screen with only the guidelines.
    I also had a look in the special factory settings menu. Canbus was set to 08 for Toyota. In the Other menu I couldn't find/check the setting called " ... prohibit ... " with the exact name.
    Any tips what to check or do differently to activate my cameras? Am I missing any special settings?
    One more question; My Toyota also has a orginal factory installed 360 camera. I saw the input socket on the Dasaita unit. However I don't know which cable from the car can connect to this socket. is there a connector in the car that fits directly to the socket on the Dasaita radio?
    Thanks for helping!!
  • @Mark Koetluk
    Please firstly check "C" has connected to either wiring "C1" or wiring "C2".
    If C with C1 cannot work for camera, please switch to connect C with C2 to see how it goes.
    Besides, please confirm the setting:
    Settings > Car > Factory setting (password :126) > Other > Reverse Detection > Enable > Apply > Exit > Reboot.
    Hello, thanks for your response!
    My:
    • Order number: SP-DA7959
    • Purchase date: Aug 6, 2025
    I already went to the car and I checked:
    • Wire C is connected to wire C1
    • And the setting Reverse Detection is Enabled
    • Cam In <> Cam Vin/ Camera: Yes, the yello cinch connectors are connected,
    • also all other cables supplied with the unit are connected together as shown in the installation posters for RAV4 2019+
    I changed wire C; I connected it to wire C2.  Unfortutely, it did not solve my problem.  I put C back to C1 - orginal position.
    I also checked the CANBUS setting; it is on 08 for Toyota.
    I tried changing to other CANBUS settings for Toyota Rav4; It does not help. So, I changed it back to the original setting no. 08. The android system rebooted a few times after changing CANBUS settings. The last android reboot was for CANBUS setting 08 / Toyota.
  • @Mark Koetluk
    1、
    For further confirmation, please tell us whether your car equipped with factory 360 camera.
    2、
    Besides, please confirm with us if it displays an exclamation mark with a black screen when you put in reverse gear.
    3、
    If possible, could you please record a video about the camera issue then send it to our mail?
    So that we can forward it to our technician for further advice.
    ✉️Email: team@dasaita.com
  • Hello @Support Dasaita
    Did you see my message above?
    Today I did the following things:
    1. Check connections - I removed the Dasaita G13 from the car and I checked all the wires and the connectors on the G13 unit. Everything is plugged in the correct sockets on the G13 unit.
      To be sure, I removed the plugs and clicked them back into the sockets; To be sure of a good connection to the G13 unit.
    2. Small electronic box connection -  There's an electronic box plugged to the wiring harness.  I removed the plug and clicked it back into the socket to be sure it has a good connection.
    3. Tomorrow I will return to the car and try installing again.
    4. To check the factory cameras, I have re-installed the original factory radio. After power on everything is working fine: the front camera, rear view camera and 360 camera are all still working good. I see video coming on the screen from all 3 cameras.  So, the factory cameras are still working in the car.
    5. Dasaita G13: balance F/R not working - I also noticed one more problem with the Dasaita G13: I can't adjust Front/Rear Balance. Looking at the installation poster the sound must come from the wiring harness connected to socket no.3 on the G13 unit.
    Questions:
    1. Could there be a wiring problem in the cable harness?
    2. Did I receive the correct cables for Toyota RAV4 2019+ from Dasaita??
    3. Can I get an optional cable to connect the factory 360 camera to the Dasaita G13 unit?
      I hope to hear back from you soon!!
    Here are my answers:
    1. 360 camera - yes, my care has the factory 360 camera
    2.  exclamation mark - yes, when putting the car in reverse I have a black screen with exclamation mark and guidelines.  When I drive forward and the parking camera is activated;  I also see a black screen with the same guidelines, but no exclamation mark. Normally these guidelines should be only displayed for the rear view. So, this is also not good.
    3. Video - yes, I will make a video recording tomorrow. I will speak in the video to tell when the transmission is in reverse drive or forward drive.
      Thanks, Mark
  • @Mark Koetluk
    Yes, we received your message.
    If possible, could you please record a video about your wiring connection then send it to our mail as well?
    Please make sure that the wiring labels are visible clearly.
    To further confirm the compatible cable, please assist to provide us with the front&back side clear photo of your factory radio.
    yes,  I will make a video + photos.
    I will have time this Friday or Saturday.  When ready, I will send it to you immediately!
     - Mark
  • to which e-mail address shall i send the video + photos?  to  Office@dasaita.com
  • After taking pictures, I removed the factory radio.
    Next I installed the Dasaita G13 one more time in the car.
    Here are the pictures of the screen with the car transmission in D and R positions. I can see from the dashboard that the parking cameras are active.
    Also, I took pictures of the cables connected to the back side of the Dasaita G13 + the product labels.
    I hope you now have enough pictures and information. Please let me know if you need more.
