Dasaita Backup Camera Feed Issue
    I recently purchased and installed the Dasaita 1080p Backup Camera Toyota Tundra 2014-2020 Tacoma 2016-2020 in my Tacoma.
    I also have the Dasaita G14 11.6" Head Unit.
    The video feed from the backup camera has Ghosting and a slight red tint. In the photos you can see the ghosting/silhouette around objects. Almost out of focus. Is this a camera hardware issue or maybe wiring issue?
    I hope it's something simple as I have already run the power cable under my truck and up into the cab. Any info is appreciated. Thank you.
  • Dear Israel,
    To ensure the specific solution for your car stereo and camera,please provide us with your Order details(Including Order Number&Unit and camera model&Version).
  • @Support Dasaita Hello, I believe I have solved the issue with the ghosting in the video feed. I will attach some new pictures. I will also attach a diagram I made showing the install/wiring method I used to get a clear video feed.
    The head unit is the Dasaita Vivid G13 11.6" Display
    I believe the camera sku is SKU: CA-802-B83 Amazon description is "Dasaita 1080p Backup Camera Toyota Tundra 2014-2020 Tacoma 2016-2020 in my Tacoma"
  • @Israel Garcia
    If your are using the harness with canbus,the reverse no need to connected.
