I got the new iPhone 17 and with the new USB-c connection via USB, the Dasaita radio is not launching carplay. ( does not work with Bluetooth either )
PX6 Andorid 11
Any ideas ?
PX6 Andorid 11
Any ideas ?
@Kurt Davenport
Dear customer,
telenav_vivid_rk3399_11.0_ota(20250401)
I tried this today but it still does not work for CarPlay either tethered or via Bluetooth.
any other suggestions ?
@Kurt Davenport
If there is an activation Code on the CarPlay page?What happen on the screen when you connect the wireless CarPlay?
I'm never promoted for any activation code.
If connected via Bluetooth to the radio, I open the CarPlay app on the radio and nothing happens.
then when I go to CarPlay on my iPhone it shows the scout option but it will not connect even though there is already a Bluetooth connection present.
@Kurt Davenport
Please go Settings > Car > Factory setting (Password: 126) > App >BT,choose following option one by one to see which one is work for the CarPlay.
1.FSC-BW124
2.WQ RF210
3.WQ-BC6
4.SDIO-AUTO
Id prefer to not use BT. Is there any troubleshooting for why the hard wire connection doesn't work ?
None of those options seemed to have any effect. I tried 3 of them and one was not available to try.
What is the delay with uploading pictures ?
Build number
rk3399-userdebug 11 RQ3A.210705.001
MCU version
MTCH_HA_V3.89a_1
@Kurt Davenport
Here is the Vivid 11 latest version
This has fixed the Bluetooth connection. Thanks !
the wired connection does not work however. Is there a way to make that work ?
@Kurt Davenport
Thank you for your reply.
Is wired bluetooth conenction?
No, bluetooth is wireless connection. That one is fixed now.
I am asking about having it use a 'wired' connection. This is using the USB port/cable from the radio. Previously this worked with my iPhone 13 using the older cable connection.
Now that its using the USB-C connection to the iPhone 17 it does not seem to recognize the device in CarPlay. The Charging function still works via the USB C though.
