iPhone 17 - iOS 26 Zlink/Carplay not working
  • I got the new iPhone 17 and with the new USB-c connection via USB, the Dasaita radio is not launching carplay.  ( does not work with Bluetooth either )
    PX6 Andorid 11
    Any ideas ?
  • @Kurt Davenport
    Dear customer,
    telenav_vivid_rk3399_11.0_ota(20250401)
    2.Format the USB drive before copying the Update.zip  file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • I tried this today but it still does not work for CarPlay either tethered or via Bluetooth.
    any other suggestions ?
  • @Kurt Davenport
    If there is an activation Code on the CarPlay page?What happen on the screen when you connect the wireless CarPlay?
  • I'm never promoted for any activation code.
    If connected via Bluetooth to the radio, I open the CarPlay app on the radio and nothing happens.
    then when I go to CarPlay on my iPhone it shows the scout option but it will not connect even though there is already a Bluetooth connection present.
  • @Kurt Davenport
    Please go Settings > Car > Factory setting (Password: 126) > App >BT,choose following option one by one to see which one is work for the CarPlay.
    1.FSC-BW124
    2.WQ RF210
    3.WQ-BC6
    4.SDIO-AUTO
  • Id prefer to not use BT.  Is there any troubleshooting for why the hard wire connection doesn't work ?
  • None of those options seemed to have any effect.  I tried 3 of them and one was not available to try.
  • Could you please go to Settings>About machine and provide the following version information:
  • What is the delay with uploading pictures ?
  • Build number
    rk3399-userdebug 11 RQ3A.210705.001
    MCU version
    MTCH_HA_V3.89a_1
  • @Kurt Davenport
    Here is the Vivid 11 latest version
  • This has fixed the Bluetooth connection. Thanks !
    the wired connection does not work however.  Is there a way to make that work ?
  • @Kurt Davenport
    Thank you for your reply.
    Is wired bluetooth conenction?
  • No, bluetooth is wireless connection.  That one is fixed now.
    I am asking about having it use a 'wired' connection.  This is using the USB port/cable from the radio.  Previously this worked with my iPhone 13 using the older cable connection.
    Now that its using the USB-C connection to the iPhone 17 it does not seem to recognize the device in CarPlay.  The Charging function still works via the USB C though.
  • @Kurt Davenport
    For your information, the USB cable for the  iPhone 17   is USB-C . This cable doesn't fit the Dasaita USB cable , so your MFI cable doesn't fit  to support the wired carplay.
