  • @Ibrah Drm You could update the zlink5. Here is the software.
    https://www.dropbox.com/scl/fi/qgg382wxy382wvoh0vbyl/zlink5-hengchangtong-release-v5.4.26-6a343d01_jg.apk?rlkey=mgyf933axspq2pya1bqh0trj4&dl=0
  • @Diego Micheli Thank you for your reply. We are wondering if you installed the DAB+ in from the APKinstaller. Or you download it from other website like google play store.
  • Play store
  • @Support Dasaita Play Store
  • @Diego Micheli We could not ensure that it work for our stereo, Please go to Apkinstaller > Install > OEM > install the DABplayer to check it you could work with DAB without defect.
  • @Support Dasaita è un app nel play Store o la trovo nel menù della radio?
  • Привіт ! Хочу оновити магнітолу, прошу поради яку версію скачати щоб все працювало стабільно
  • Hello !  I want to update my radio, I would like advice on which version to download so that everything works stably
  • @Ihor Barskyi
    Vivid 10 VersionMake Sure your unit is PX6 Andorid 10(Scout maps are only available for the US and will be hidden in other areas.)
    telenav_vivid_rk3399_10.0_ota(20231102)
    https://www.dropbox.com/scl/fi/v7707hov1gkj950zpt0pc/update.zip?rlkey=h0qynk6ehsy91yto3ka4frgt0&dl=0
  • @Support Dasaita Thank you for your reply.  Yes, I have android 10. I live in California
    I have bought HA2158-MAX10 bought from your official store on Aliexpress
    Order ID:  8128503217275443
    Order placed on:  Mar 29, 2021
    The descrioion of the product says:
    Dasaita 10.2" IPS Screen 1Din Car Android 10.0 DSP for Jeep Wrangler Radio 2011-2016 Bluetooth 1080P Video 64G ROM MAX10
    I have been using the device for more than 2 years, and I have always using my phone hands-free. (I changed several phones in the meantime).
    I can hear the other side good enough, but the other side always complains that I speak like an alien.
    Strangely enough, I used an app for microphone testing, and it works just fine, which means that the microphone is operating OK.
    I want to upgrade the MCU and the Operating system (Firmware).
    Please find attached screenshots of the device (it says MAX10 with 1024x600 display).
    Please give me links with the suggested MCU and firmware updates.
  • @Milan Petrovski We found your order is about 3 year, please kindly let us know if the receiver heard your voice like alien since the date that you installed the head unit. If yes, we may suggest you to update the firmware.
    MAX10(20230302):
    https://www.dropbox.com/s/5w50x3fqkvhiv3f/ha3_rk3399_10.0_ota%2820230302%2B%E8%93%9D%E7%89%99MCU%29.zip?dl=0
  • @Support Dasaita Thanks for your swift reply.
    Yes, it was like that since beginning. I will try to update the firmware during the weekend.
    Hello, where can I find the latest MCU for MTCH? I do not see MCU updates listed on the firmware update page.
  • @Michael Uribe We would like to tell you that MCU is usually for hardware issue, so we do not list it on the forum now. Please kindly demonstrate your issue so that we could better confirm and give you instruction.
  • @Support Dasaita I have the new Android 12 version with LTE. When I'm using the LTE it is very intermittant. It will connect and stay connected for 2-5 minutes but then disconnect. To get it to connect again I have to turn the SIM off and then back on again in the settings. Below is my current build and MCU version.
  • Hi@Support Dasaita
    I have the following dasaita head unit purchased around 2020 and im trying to see if there are updates/security patch I need to install? Kindly please advise. Thank you.
  • @Support Dasaita Where can I get the Dasaita "Camera APK" to display the reverse cam while driving?
    Vivid 11 and Scout does not include the APP.
    Please let me know, thanks.
  • when will there be a new update release for android 10, and hopeful with the googlemaps  on the main screen, the ui for the new rom is uggley as hell, and so is it with using split screen, thats for me a reason not to do the new update , because its removes the beauty of the vivid ui. the split screen is crap jus gives us the ui back with google maps on the main screen not everone use scout not everyone lives is phuckin America ,
    when will a new update finaly come with real ui of vivid on it without that scout crap pr split screen crap.
  • Help needed, Just purchased and installed the Model 2220/5480 in my 2018 Tundra limited. I got everything working , Radio, Backup Cam, wheel controls etc. Installed the unit yesterday and today the screen is frozen with Dasaita on screen. Tried reset, remove radio fuse, wait 3 min, simultaneoulsy turn to ACC and press reset till recover appears. Nothing ever appears just loops back to Dasaita screen.
