@Luigi Torav Sorry that Android 10 firmware is not compatible with your Android 8 stereo, it may defect the unit in some pespects.
Hello, I am having problems with crashing applications and car camera view freezing, I am on px5(1024x600) Android 8, MCU version MTCE_HA_V3.56_1, what is the correct upgrade for Android 10? can you please send me instructions.
Thanks, can you suggest my the best solution in order ti solve the camera freezing problema?
@Luigi Torav Maybe you could try factory reset the system.
Vivid 11 Version Make Sure your unit is PX6 Andorid 11(With pre-installed Scout map, if you don't want it, please unistall.)
telenav_vivid_rk3399_11.0_ota(20231208)
I would like to update my dasaita vivid 11 but I don't know if I have scout map pre-installed. If it is not installed, can I update it anyway? or do I have to install scout map first?
Diego
@Diego Micheli We have pre-installed the scout map in this firmware, if you don't want the map, you could uninstall it.
@Support Dasaita non ho trovato la mappa scout dopo l'aggiornamento. Dove la posso trovare? Che novità ci sono nel nuovo aggiornamento. Non ho trovato differenze ne grafiche ne altro.
Hola me gustaría saber si hay alguna actualización para este dasaita.
Muchas gracias.
@Diego Micheli The map is on the left widget.
@OCDO We would like to tell you that our latest version is on 20211023. According to your screenshot, we could not see the build number to check the version, please kindly send us again. In this case, we could check your current version and tell you if you could update it.
MAX6 Version :
PX6 HA2_rk3399_9.0_ota(20211023) https://www.dropbox.com/s/h8zjji07bn8mopo/HA3_rk3399_9.0_ota%2820211023%29.7z?dl=0
@Support Dasaita espero que con esta imagen sea suficiente. Muchísimas gracias.
Which latest firmware do i need for this px6 unit? can you provide a link, please?
@OCDO You could try to update this version./Podrías intentar actualizar esta versión.
MAX6 Version :
@Support Dasaita This is our latest Android 11 version with Vivid UI and scout map.
Vivid 11 Version Make Sure your unit is PX6 Andorid 11(With scout Map)
https://www.dropbox.com/scl/fi/v1i0my6sqzrd5fvmj53bs/update.zip?rlkey=6fzaenktzor2zx58sg9iau0sg&dl=0
Hello, I want to update Android. Is this possible?
Im not sure if this is correct, but do you know which version can I upgrade here? I think mine is PX6 but I dont know correctly an dI dont want to break it.
@Support Dasaita È normale che ogni volta che accendo la radio parte subito ma poi dopo un po il tablet si riavvia da solo. Ho un Vivid 11 con questo firmware:
E poi Maps l'altro giorno sembrava che il GPS non prendeva bene perché la freccia andava a scatti.
Non mi era mai successo.
@Ruslan Russakov We would like to tell you that your current version is 20181210 and the latest version is 20190731, so you could try to update the system.
V840-8 Version :
@jesus otero We are wondering if you could send us your order detail so that we could locate more information and give you appropriate instruction. Your prompt reply will be appreciated.
