@Support Dasaita Please read my previous post.
Also, could you post the previous Vivid 11 firmware OTA without the Scout combine please.
Can you please provide steps on how to downgrade from Android 11 to Android 10 and install the SCOUT firmware.
Thank you.
@Zeek World Thanks for the warning. That sucks the Scout APK messed up your Vivid 11 Combined install. At least you were able to get it back with a factory reset. Better QA is needed with these releases though.
With my Vivid 10 Combined firmware and the Scout APK installed, my unit is still running okay (so far).
@Elite Android
I have to find a way to downgrade to Android 10 from 11, looks like Dasaita pulled their video and full images from here, I may have to contact them direcly since I purchased the unit from them.
Another reason to downgrade to Android 10 is I have the darn bluetooth module which in theory Dasaita says is not compatible with Android 11 and can't use standby since unit has to cold boot with every restart to connect to phone. Painfull.
Woudn't mind switching to Scout but first I need to downgrade to Android 10.
Hi, I updated the car tablet, everything went fine but the first time I restarted it the screen remained black. I tried to enter recovery mode but the screen is always black. How could I solve it? I would like to point out that the car radio seems to work as the radio is listened to but the screen is always black. Thank you
@Zeek World Yeah the cold boot each time sure isn't ideal, and with Android 11 the bootup times were longer for me than Android 10.
Iker Gomez posted a complete walkthrough that was used to rollback to Android 10 after an 11 firmware update was incorrectly labeled as 10 earlier in the year.
https://www.dasaita.com/community/forum/topics/index/86408/incorrect-android-version-in-current-max10-px6-firmware-provided-by-dasaita-stuck-on-android-logounusable
Scroll down to Iker Gomez's step by step post, though as he said, the downgrade/upgrade process isn't supported or endorsed by Dasaita.
@Roar H Which store that you bought from and please send you order number?
@Luis21
Vivid 11 Version Make Sure your unit is PX6 Andorid 11(Combine scout and vivid)
telenav_vivid_rk3399_11.0_ota(20231023)
https://www.dropbox.com/scl/fi/cc239gx68witzm8x3arbu/update.zip?rlkey=xjj2dqc54lhg71vwqqhiuc11a&dl=0
@Zeek World Do you mean that you stuck in the Dasaita logo?
@Zeek World Do you mean that you have an Android 11 head unit and want to downgrade to Android 10 to switch to scout? We are going to release a new head unit with pre-intall scout map and are testing now. Please kindly wait for it.
This is where i bougt it:
This was about 5 years ago, to i don't have the order number or any information about this anymore.
The only info i have is that i bougt it on july 2018.
Correct, like I wrote before.
If you have Vivid 11 updated with the latest combine ota and install the Scout APK you will get stuck at Dasaita logo on the next reboot.
You guys should try to replicate this and perhaps pull the latest ota combine update so other user's won't hit the same issue.
Correct, ok, I will wait for the new file with the Scout maps pre built then.
Just let me know if you want me to test it, I am a network engineer pretty savy on the matter and wouldn't mind to help out.
@Elite Android
Thanks!! Will look at this in a few.
@Support Dasaita Hi, I bought the Dasaita android player from a Facebook CX5 member. He bought in bulk quantities directly from China. Unfortunately I am not able to provide you the proof of purchase. But I have the photos of the original box of the Dasaita player, please refer to the attachment.
I have a Wondefoo PX6 radio. Can I install the latest dasaita update?
Apps like Spotify/Gmaps crash and close unexpectedly and I can't get Carplay to work with ZLINK.
@Support Dasaita I am trying to update my Vivid 11 unit, because it is having some problems (about 1 in 3 times I start the car, the screen does not show and none of the functions seem to work except for the backup camera.
This is the info before the upgrade:
I am trying to upgrade using this file:
After the update, I am being asked to run the Scout setup, which then gets stuck at the point where it is trying to set up wifi. I don't have any instructions for how to do that, and it just spins at that point.
I was able to complete the setup using my phone's wifi hotspot. It seems, however, that doing this leaves me with Scout rather than Vivid. I'm not sure how much of an issue this is for me, since I'm pretty much using the unit for Android Auto, and it seems to be working better with the newer firmware.
@Miguel Lai Could you kindly try to update the firmware to the version 20190731?
ha_px5_8.0_ota(20190731) https://www.dropbox.com/s/0l1bibw0h9ktt9q/ha_px5_8.0_ota%2820190731%29%E5%8D%87%E7%BA%A7%E5%8C%85.zip?dl=0
