@Mcgyver83 We would like to tell you that we have improved the zlink and fixed some bugs that reflected by our customers. If you have not sufferred from any malfunctions, we don't suggest you to upgrade the version. Hope you can understand..
Ok, I'm not able to connect to AA via Z-Link with my RedMi A2 nor Huawei P10 lite. Dasaita simply shows "Waiting for connection" even AA is running on my smartphone screen.
Not as plug&play as AA but I was able to use screen mirroring (but of course, is not the same)
Do any of suggested actions cause data loss? I mean I can remove pairing info from stereo and phone and wifi settings without issue but I cannot deal with big stereo reconfiguration now. (I mean something like factory reset of the stereo)
@Mcgyver83 We will like to tell you that storage clearing may cause settings loss. But it might solve your problem as well. Please kindly try the solution that we provided.
Sorry for the delay. Before opening the thread I tried also with a RedMi Note 9 Pro without succes. Now that I got your suggestion I don't have an Android smartphone compliant to Android Auto Wireless (RedMi A2 and Huawei P10 lite are too old). I'll try your hints as soon as possible.
I used another smarphone, Android Auto Wireless compliant and works with my Z-Link app. Ok, takes more than 20seconds to connect but it works. Then I have another problem: dasaita WIFI doesn't stay on and each time that smartphone connects to bluetooth Android Auto starts. I think that I should decide if I want to use Android Auto or not :)
Then I tried with my old smartphone, Android Auto updated late August on the smartphone, usb cable connected to the dedicated usb plug in the car but Z-link stays like below forever. I see Android Auto notification in my smartphone.
@Mcgyver83 on the zlink settings disable the background connection option.
By that option disabled....if zlink is in background the wifi will not disconnect.
That wifi disconnection is due to zlink is forcing to enable the headunit wifi Hotspot to transmit the android auto video signal by direct wifi connection.
Hello. Could you please tell us the reason why you want to do the update? We'd like to remind that the update operation involves the potential risks. For this reason, we suggest that you can keep the current version to use if the unit can work normally.
https://www.dropbox.com/scl/fi/9fkhng2srynadlzvohbc6/update.zip?rlkey=jqnm8ksr6althxiq45w7a35ld&dl=0 1.Please download the file though the link via your computer/laptop.
@Ryley Winter Could you send us screenshot or video to demonstrate the situation, additionally, you could go to Settings > About Machine and send us the current Build Number and MCU version as well?
I have a unit for a 2008 Tundra that quit working It tries to load and shows a screen that says Quit or Try again. It looks like I need to update something but i do not not know what to do. Im not sure what version or other info I need? I cannot get to the screen that tells me version number etc. the number on the box is HA5440H-Vivid11-CP-HD-4-US
1.Find a pin, press and hold the RST button for 15 seconds to see if you can enter the factory setup page, if you can, select factory reset and reboot the unit;
NOTE: Make sure you press the RST button vertically and firmly, you should feel a slight press, or even hear a faint click.
2.Please remove all the wiring and then reconnect the unit.
