Bought a tmobile Sim off Amazon. Tmobile and other carriers all say the IMEI is not compatible for GSM service. Is the device locked for US service?
I have the same problem with my Verizon SIM card. I called customer service and the said the IMEI number is not supported and is for a china phone. I don't know what SIM card to use with this device.
@Support Dasaita Same issue here with my T-Mobile SIM. They say the IMEI is not compatible on their network. It appears to me they blacklisted the device. When I searched the IMEI number, it belongs to a China phone Realme Narzo 50i, released in October 2021 . They said that device is not supported by them according to T-Mobile tech support.
At this point I'm seriously considering returning this stereo and getting something more reliable. I've tried 3 different SIM cards with none working yet.
@Support Dasaita yes the same SIM card works in my other phones aswell . T-Mobile says the IMEI is not compatible on their networks. No matter how much troubleshooting I've done , all Support reps say the same thing . IMEI is no good on their networks.
@Support Dasaita at this point, why don't you get a tmobile Sim card and figure it out at your end instead of wasting time going back and forth taking this matter much longer to resolve. Yes it's happening to every tmobile Sim card and yes they all still work just fine when trying it out on our mobile devices. Bottom line here is that our tmobile Sim aren't working any longer on your devices. It was doing fine for a long time and yes it was working.
@Hung Tran We are actively testing this issue on our end. This problem requires not only coordination with T-Mobile, but also reconfiguring relevant data for full compatibility. We are working hard to resolve it as soon as possible and will keep you updated with the latest solution once available.
Thanks for your time so much.
Please keep us updated on resolving the T-moble data sim issue. Seems to be a widespread issue affecting everyone who uses T-mobile provider. Thanks
As many of us G13 owners have found, roughly a month ago, all of our sims stopped connecting. This was true for any sim that uses the T-Mobile network, e.g. Speedtalk and Tello. The interim solution that I've found is to use an Internet of Things (IOT) sim from a provider that uses AT&T.
EIOTClub has dual network sims that provide AT&T and T-Mobile. I got one of their sims from Amazon and tested it in an old Samsung Note 8 phone. For it to work required creating a new APN set to america.bics and turning on Global Roaming. It registered immediately. I removed the sim from the phone and put in my G13. I didn't have to do anything -- the G13 immediately recognized the sim, registered it on the AT&T network, and I've got internet via LTE again.
You can get a 300 MB sim from Amazon for $5. If it works for you, you can buy a monthly plan. As I don't need much data, I got a 2GB / 30-day plan for $10/month. This a bit more than I was paying with SpeedTalk and Tello, but it works. :)
Don't forget to restart the G13 after installing the new sim.
I have no connection with EIOTClub, other than I bought a plan from them. There may be other AT&T-based sim cards out there that will work, but EIOTClub was the first I tried and it works well.
My G13 has a 15 digit IMEI number but every lookup I tried said it was invalid and one said the 15th digit was not a valid check sum.
@jdyork99 Hi,
May we know what you are trying to use the IMEI for? For example, are you trying to check compatibility or activate the unit with T-Mobile or another carrier?
@Support Dasaita lets cut the run around, we respectfully request you fix this issue . It's been months . A new update should have already been made available or you should have worked it out directly with T-Mobile already on why they blacklisted our devices . We need a solution promptly.
@JD1 Hi ,Please provide you order ID to our support email.
We will have a dedicated support representative follow up with you to help resolve this issue as quickly as possible.
Thank you for your patience and cooperation.
support@dasaita.com
