  • @Luis Laborde
    Thank you for your reply.
    May we have a video of showing the skip button when turning ?
    If you would like to connect the CarPlay automactically,please go to the Carplay APP >Settings>Background connections>ON .
  • @Rayo Pizarreno @Support Dasaita any news??????
  • @Rayo Pizarreno
    Hello,may we know your concern?We didn't locate the post from you
  • @Support Dasaita I am currently on the most recent update you guys released a couple years ago. I believe we need a new update to fix this problem with the root being detected causing newer apps to not function due to root being detected.
    Any updates?
  • @tone T
    It is a shame that the Max 10 has stopped receiving updates.
    As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices.
  • Am I able to update to max11 from max10? Considering it's the same exact hardware
  • @tone T
    Thanks for your message.
    For your information, it doesn't support to update the later system MAX11 from MAX10.
    We recommend not to do the mandatory installation for another different system to avoid the potential damage to the machine or results in bricked unit.
