  • @Luis Laborde
    Thank you for your reply.
    May we have a video of showing the skip button when turning ?
    If you would like to connect the CarPlay automactically,please go to the Carplay APP >Settings>Background connections>ON .
  • @Rayo Pizarreno @Support Dasaita any news??????
  • @Rayo Pizarreno
    Hello,may we know your concern?We didn't locate the post from you
  • @Support Dasaita I am currently on the most recent update you guys released a couple years ago. I believe we need a new update to fix this problem with the root being detected causing newer apps to not function due to root being detected.
    Any updates?
  • @tone T
    It is a shame that the Max 10 has stopped receiving updates.
    As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices.
  • Am I able to update to max11 from max10? Considering it's the same exact hardware
  • @tone T
    Thanks for your message.
    For your information, it doesn't support to update the later system MAX11 from MAX10.
    We recommend not to do the mandatory installation for another different system to avoid the potential damage to the machine or results in bricked unit.
  • @tone T It can be done, i have done it, A10 to A11, and my GPS stopped working.
    Than i flashed back to A10 and the GPS still would not work, so dont do it.
  • Hello! I have a G12. Is it possible to downgrade the firmware version? Where can I find previous versions?
  • I dont think so. Why would you downgrade?
  • @Chriss PC Fix I have a Nissan Qashqai J11 and the 360 camera button does not work and the main screen (in front of the driver) displays the clock at 12:00. On the main page of the car's tablet, the clock bar cannot be removed.
  • @ALESSIO FRATTARUOLO @Support Dasaita
    Then wait for Support Dasaita - they can give you the downgrade information and firmware (ROM).
    As far as i know, Android does not let you flash to an older Date.
  • @Chriss PC Fix thanks for the reply, oh okay so GPS didnt function anymore? Or the GPS app disappeared? Everything else function correctly except the gps then? Which one did you use to upgrade?
  • @Rayo Pizarreno
    Cześć Rayo. Miałem dokładnie ten sam problem z moim urządzeniem. Metodą prób i błędów udało mi się wgrać stare oprogramowanie 9.0 i ekran działał, ale Bluetooth z nim nie działa. Ale przynajmniej coś widzę i mogę ponownie zainstalować poprawny system, ten, który powinien na nim działać. Czekam tylko na odpowiedź od Dasaita na temat tego, który z nich wgrać na moje urządzenie. Znalazłem opis od jednego z członków zespołu i to mi pomogło. Aby wgrać aktualizację na pendrive, najlepiej wgrać działający system który 100% pewności, że dzialał. 1. Przytrzymaj przycisk resetowania i podłącz napięcie, trzymaj przez 15 sekund. 2. Na czarnym ekranie szybko kliknij trzy razy w rogu ekranu a nastepnie przytrzymaj raz długo (np 5 sec). 4. Na czarnym ekranie szybko kliknij dwa razy i znowu raz długo (np. 5 sec). Od tego momentu odczekaj pięć minut, a następnie kliknij długo raz (np 5 sec). Urządzenie powinno się zrestartować i coś wyświetlić. Spróbuj tego, u mnie zadziałało.
    I'm looking to do the beta update for the G12. What are the benefits? Is there anymore support for the G12?
  • @Support Dasaita just saw an Android 13 update (G13 Version) 20250903. is this update stable? i like to keep my unit updated but have had bad experiences with updates on a previous unit therefore i am asking before attempting to install this one.
  • @Kendall AustrieHi Kendall,is anything not working correctly?If no problem of the unit,wo don't recommend to update.
  • @Nick M Hi Nich,is anything not working correctly?
  • @Support Dasaita thank you.
  • Does anyone know what the sub preout voltage is? Also for the sub setting, is the fader all the way down at 0db unity gain? 0 as in the position where the audio signal's level is neither boosted nor reduced. Or is "12" unity gain? They do not specify anywhere and their screenshots on the updated android 13 headunits reversed the 0 position and -15 as the lowest. Thank you for your help.
