please, can somebody provide this link: Link for MAX11 PX6 android 11 IMAGE file HA3_rk3399_11.0280220413
Thanks!
Il video delle istruzioni è privato. Come si fa a vederlo?
please, can somebody provide me this File Vivid11 PX6 android 11 IMAGE file telenav_vivid_rk3399 PLEASE and the vidio Tutorial Please
@Support Dasaita could i try it?
@Jesus Sancer
You could flash the system but it is a little complicated. Please kindly refer to the steps below first.
1.After starting the machine, use the single-plug USB cable to connect the machine with the computer.
2.Open “FactoryTool.exe”, click “Firmware” option to choose the file of system version for burning.
3.After finishing the loading of firmware file, please choose “Restore”option, and then click “Run” button.
4.Long press “RST” button with a pin tool until the lights on the panel buttons flashing three times, then extinguishing for a while and lightening again. At this moment, you can release the “RST” button.(If there is a physical shutdown button, it can also be operated) Next, FactoryTool software will start the burning process automatically.
If the burning process fails, please power off the machine and then turn it on and repeat the operations above.
Here is a video link for you below. We suggest you to view the video first and then you can look through the steps above. In this way, you may have a better understanding how to do it.
Android 10 (vivid10)Flash file:
Link for MAX10 PX6 android 10 IMAGE file
Can someone give me this image?
Thanks!
I have upgraded my PX6 from Android 10 to Android 11, and now the GPS cant find any satelite.
I guess that the Drivers are not the same, so i need the PX6 MAX10 IMAGE to downgrade it to Android 10.
Thanks!
@Chriss PC Fix Here is the Android 10 (vivid10)Flash file that we sent you before:
