IMAGE Update (Android 10 to Android 11)
  • I'd add that running a help command for rkflashtool from command line gives me this feedback but I'd appreciate some help interpreting how to make use of the associated detail:
    Microsoft Windows [Version 10.0.19043.1645]
    (c) Microsoft Corporation. All rights reserved.
    [prompt]>rkflashtool /?
    rkflashtool: info: rkflashtool v6.1
    rkflashtool: fatal: usage:
            rkflashtool b [reset_flag]              reboot device
            rkflashtool l outfile  read IDBlocks
            rkflashtool j offset nsectors outfile  read SDRAM
            rkflashtool M offset nbytes   outfile         read flash partition by name
            rkflashtool w partname outfile  read flash partition
            rkflashtool w offset nsectors file                     fetch parameters
            rkflashtool P
  • @No4 Mk2 Can you tell us what head unit do you have, is it a Dasaita Max 10 or Max 6 running Android 10? Do you want to upgrade to Android 11 from Android 10?
    The zip file you are using appears to be the one for the new motherboards (HCT8) and that is an OTA zip file, not a full image file to upgrade from Android 10 to Android 11.
    More information is needed from you about your device specifications and what is what you are trying to achieve.👍
  • @Al Ferro thanks for asking.
    The unit in question is a Dasaita MAX10 Universal Double DIN Car Stereo 7 Inch Carplay Android Auto PX6 4G+64G Android10 1024*600 DSP AHD Radio (Dasaita SKU: HA2153-MAX10-CP).
    Max10 wasn't playing nicely with Bluetooth, so I flashed the most recent (at the time) Vivid10 image via USB no problem. Yesterday, the OS advised of an OTA update so I gave that a go ahead.
    Refer screenshots of the "as installed" About detail from the unit for info:
    Yes - that was my thinking. The unit hasn't been installed and I'm running it from a bench power supply for function testing. I was thinking that upgrade to Android 11 would make sense given where it is. Easier than doing it in-vehicle.
    Fair point but the file detail referred to is the same (AFAIK) for the Vivid11 .zip file, so it was purely for illustrative purposes. Apologies for any confusion. I was trying to show the extent of the investigation that I've made and that I'm not completely clueless.
    Also, I can see from the Post #1 that (for example) there is this advice:
    Link for Vivid11 PX6 android 11 IMAGE file telenav_vivid_rk3399_11.02820220413
    please ask seller
    So, I sourced the unit via Amazon but I don't understand why a usable image is not directly available from the original equipment manufacturer. As I explained above, I flashed Vivid10 from Max10 using the firmware image published on this site at:
    https://www.dasaita.com/community/forum/topic/36770/firmwares
    I think that covers it. Hopefully, I've been sufficiently clear. Thanks.. 😉
  • hello I faced a similar problem
    I thought I bought max 10 So I downloaded the latest max 10 Firmware  but the device does not boot anymore. I'm stuck with logo bootloop
    To make things worst I cannot enter recovery  mode
    i tried everything but no success
    I when I checked the box I discovered they sent max11
    can anyone help
  • @Gaby Rouss https://www.dasaita.com/community/forum/topic/62009/important-how-to-enter-into-recovery-menu. Did you try to correctly get into recovery mode?
  • @Al Ferro yes I tried 👎 after 8 seconds it flashes 3 times, I kept pressing for 30 seconds nothing happened, and to make things worst the unit freezed, I had to unplug it
  • Hi,
    Can I request to upgrade from Max10 to max 11?
  • Am I able to get Link for Vivid11 PX6 android 11 IMAGE file telenav_vivid_rk3399_11.02820220413 link?
  • @Tony Ye  Hey Tony, i finaly fix it - now its running MAX11 Android 11.
    Only thing that does not work is the GPS.
    Any tips what to do?
    Antena is OK.
    Thanks!
    Antena is OK.
    Thanks!
  • @Zeek World could you please give me a step by step on what you did? I'm screwed with the exact same issue you had and I have no idea how to fix it because I can't find anything online about it. I can't get into recovery mode no matter how hard I try and I tried to do vivid10 and realized I was running max11 way after the fact so I'm just in an infinite boot loop
  • @Chriss PC Fix Great to know. Congrats! Is there any GPS issue under Android 10? My one works fine.
  • Hi, I tried to upgrade to android 11 following the video and the flashing process failed with IDB download failed and now stuck in flashing mode (black screen) with touch button lights on. I cannot get out of this no matter if I hold reset buttons for how long. and PC cannot recognize device via USB (device descriptor failure).
    i swtiched to different PC and different USB port, and same.
    now I stuck in this flashing screen and pc not able detect the device to flash, what should I do now?
    first with factory tool error:
    12:08:40 142	Factory Tool v1.5.0.0 start run
    12:31:42 180	Factory Tool v1.5.0.0 start run
    12:34:13 330	Layer<7,1-1-1>:Switch ADB Start
    12:34:13 332	Info:RunExe->cmd=netstat -ano
    12:34:14 943	Info:RunExe->cmd="C:\Users\hangsun\Downloads\FactoryTool-1.72.7-1\FactoryTool-1.72.7-1\FactoryTool\bin\adb.exe" -s BQBYMRUX18 reboot loader
    12:34:21 744	Layer<7,1-1-1>:Switch ADB Success
    12:34:21 823	Layer<7,1-1-1>:Wait For Loader Start
    12:34:25 536	Layer<7,1-1-1>:Wait For Loader Success
    12:34:25 549	Layer<7,1-1-1>:Download
    12:34:25 561	Layer<7,1-1-1>:Test Device Start
    12:34:25 575	Layer<7,1-1-1>:Test Device Success
    12:34:25 588	Layer<7,1-1-1>:Get FlashInfo Start
    12:34:25 590	 INFO:FlashInfo: 00 00 50 07 00 04 04 00 28 00 01
    12:34:25 601	 INFO:GetFlashInfo-->Emmc storage.
    12:34:25 610	Layer<7,1-1-1>:Get FlashInfo Success
    12:34:25 624	Layer<7,1-1-1>:Prepare IDB Start
    12:34:25 633	 INFO:CS(1)		(59904MB)		(SAMSUNG)
    12:34:25 661	Layer<7,1-1-1>:Prepare IDB Success
    12:34:25 677	Layer<7,1-1-1>:Erase IDB Start
    12:34:25 683	 INFO:EraseIDB-->Erase count=12.
    12:34:27 487	Layer<7,1-1-1>:Erase IDB Success
    12:34:27 529	Layer<7,1-1-1>:Reset Device Start
    12:34:28 544	Layer<7,1-1-1>:Reset Device Success
    12:34:28 584	Layer<7,1-1-1>:Wait For Maskrom Start
    12:34:59 040	[Error] Layer<7,1-1-1>:Wait For Maskrom Fail
    12:37:15 124	Factory Tool v1.5.0.0 start run
    12:40:52 505	Factory Tool v1.5.0.0 start run
    12:41:15 922	Factory Tool v1.5.0.0 start run
    13:36:55 413	Factory Tool v1.5.0.0 start run
    13:44:05 535	Factory Tool v1.5.0.0 start run
    15:58:45 373	Factory Tool v1.5.0.0 start run
    16:24:55 616	Factory Tool v1.5.0.0 start run
    then i tried Android Tool Release 2.71 with this Error:
    11:42:38 118	RKDevTool v2.7.1.0 start run
    12:17:10 440	RKDevTool v2.7.1.0 start run
    12:19:31 503	Layer<1-1-1>:Test Device Start
    12:19:31 511	Layer<1-1-1>:Test Device Success
    12:19:31 547	Layer<1-1-1>:Check Chip Start
    12:19:31 573	Layer<1-1-1>: Check Chip Success
    12:19:31 599	Layer<1-1-1>:Get FlashInfo Start
    12:19:31 620	 INFO:FlashInfo: 00 00 50 07 00 04 04 00 28 00 01
    12:19:31 649	 INFO:GetFlashInfo-->Emmc storage.
    12:19:31 682	Layer<1-1-1>:Get FlashInfo Success
    12:19:31 708	Layer<1-1-1>:Prepare IDB Start
    12:19:31 727	 INFO:CS(1)		(59904MB)		(SAMSUNG)
    12:19:31 766	Layer<1-1-1>:Prepare IDB Success
    12:19:31 772	Layer<1-1-1>:Download IDB Start
    12:19:31 877	Layer<1-1-1>:Download IDB Success
    12:19:31 889	Layer<1-1-1>:Download Firmware Start
    12:19:31 910	 INFO:FlashInfo: 00 00 50 07 00 04 04 00 28 00 01
    12:19:31 935	 INFO:GetFlashInfo-->Emmc storage.
    12:19:31 959	 INFO:Start download image,total=3336509731,band=64,DirectLBA=1,First4Access=1,Gpt=1
    12:19:32 000	 INFO:Start to download trust,offset=0x6000,size=4194304
    12:19:32 334	 INFO:Start to download uboot,offset=0x4000,size=4194304
    12:19:32 628	 INFO:Start to download misc,offset=0x8000,size=49152
    12:19:32 638	 INFO:Start to download boot,offset=0xe800,size=26580992
    12:19:34 534	 INFO:Start to download dtbo,offset=0xc000,size=803
    12:19:34 543	 INFO:Start to download vbmeta,offset=0xe000,size=4096
    12:19:34 569	 INFO:Start to download recovery,offset=0x1e800,size=38283264
    12:19:37 293	 INFO:Start to download super,offset=0x150c00,size=3263168512
    12:22:41 029	Layer<1-1-1>:Download Firmware Success
    12:22:41 042	Layer<1-1-1>:Reset Device Start
    12:22:42 081	Layer<1-1-1>:Reset Device Success
    12:35:56 270	RKDevTool v2.7.1.0 start run
    12:39:45 936	RKDevTool v2.7.1.0 start run
    13:31:32 715	RKDevTool v2.7.1.0 start run
    13:32:26 486	Layer<1-1-1>:Download Boot Start
    13:32:32 226	Layer<1-1-1>:Download Boot Success
    13:32:32 230	Layer<1-1-1>:Wait For Maskrom Start
    13:32:32 861	Layer<1-1-1>:Wait For Maskrom Success
    13:32:32 869	Layer<1-1-1>:Test Device Start
    13:32:32 882	Layer<1-1-1>:Test Device Success
    13:32:32 896	Layer<1-1-1>:Check Chip Start
    13:32:32 910	Layer<1-1-1>: Check Chip Success
    13:32:32 922	Layer<1-1-1>:Get FlashInfo Start
    13:32:32 932	 INFO:FlashInfo: 00 00 50 07 00 04 04 00 28 00 01
    13:32:32 945	 INFO:GetFlashInfo-->Emmc storage.
    13:32:32 962	Layer<1-1-1>:Get FlashInfo Success
    13:32:32 973	Layer<1-1-1>:Prepare IDB Start
    13:32:32 982	 INFO:CS(1)		(59904MB)		(SAMSUNG)
    13:32:32 999	 ERROR:FindBackupSector3-->Check Crc Failed
    13:32:33 012	Layer<1-1-1>:Prepare IDB Success
    13:32:33 025	Layer<1-1-1>:Download IDB Start
    13:32:33 068	Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=241664,write=0
    13:32:46 040	ERROR:RKU_ResetPipe-->DeviceIoControl failed,err=995
    13:32:46 042	 ERROR:WriteIDBWithDirect-->RKU_WriteLBA failed,ret(-3),lba(3136)
    13:32:46 066	 ERROR:DownloadIDBlock-->WriteIDBWithDirect failed
    13:32:46 094	Error:Layer<1-1-1>:Download IDB Fail
    13:33:08 790	Layer<1-1-1>:Download Boot Start
    13:33:13 880	 ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(116738),Sended(0),bRet(1),err(0)
    13:33:13 882	 ERROR:DownloadBoot-->Boot_VendorRequest471 failed,index(0)
    13:33:13 910	Error:Layer<1-1-1>:Download Boot Fail
    13:35:04 640	RKDevTool v2.7.1.0 start run
    13:38:16 507	RKDevTool v2.7.1.0 start run
    13:41:21 349	RKDevTool v2.7.1.0 start run
    13:45:01 795	RKDevTool v2.7.1.0 start run
    13:45:05 472	Layer<>: RunProc is ending, ret=0
    13:46:40 576	Layer<>: RunProc is ending, ret=0
    13:48:08 896	RKDevTool v2.7.1.0 start run
    15:48:06 965	RKDevTool v2.7.1.0 start run
    15:53:46 627	RKDevTool v2.7.1.0 start run
    16:11:51 448	RKDevTool v2.7.1.0 start run
    i am so stuck now, and i don't install the head unit myself, i cannot unplug the unit easily.
    main problem is I cannot get the head unit detected by windows. I just want to go back to working state, max10 or max11
    @Chriss PC Fix how do you get the pc detect the head unit again?
  • Is there anywhere showing the steps to follow to upgrade 10 to 11?
    Dasaita PX6 MAX10
    Model: HA2102-MAX10-CP-HD
  • @Alf Red bump
  • 1
  • Is there a step by step guide to update max 10 to max 11. looking for zlink upgrade through OTA updates. Unit does work good or should I just root and update files 🤔 👀 😬.
  • Can i finally upgrade max10 to A11 with a valid Bluetooth?
  • 1
  • @Tony Ye Is windows 11 the right version we need to use ... or can we use an older one like a windows 7 to install these drivers and restore my Unit. My Issue is i tried an updated from Andriod 10 to 11 and  the system starts saying 11 andiod system ... the dasiata logo comes on and nothing after that just gets stuck there. Tried multiple times but never got to the recovery screen. Also another question if the headunit is at stuck at that logo .. how would i know that the unit gets recognized at my computer ... any help would be appriciated thanks you
